TractorLinks.com
Show Parts for Model:
Re: Allis Chalmers b
Zachary Hoyt
12-18-2012 15:23:48
Does it have a magneto or a distributor? In either case you would want to check on the points and rotor and cap to make sure the contacts are clean and the point gap is correct. If a distributor you would want to check that battery voltage was getting to the coil. There is a lot more to do if these things don't fix the problem but they are a place to start.
Zach
jeff-h01
12-18-2012 15:26:29
 Re: Allis Chalmers b in reply to Zachary Hoyt, 12-18-2012 15:23:48
Its a mag..no battery
old
12-18-2012 15:53:32
 Re: Allis Chalmers b in reply to jeff-h01, 12-18-2012 15:26:29
Most likely the points need to be replaced or cleaned BUT depending on the mag you also have to know how to install the rotor the correct way or you will get it way out of time. Send me an e-mail and tell me which mag it is and I can then send you the manual for your mag so you can do it the correct way
jeff-h01
12-18-2012 17:09:51
 Re: Allis Chalmers b in reply to old, 12-18-2012 15:53:32
I'm not sure which one it has...its a 39 serial number b32474 if that helps...to shut it off it has a little thing on the side to ground it out...lol sorry not much info
old
12-18-2012 17:31:13
 Re: Allis Chalmers b in reply to jeff-h01, 12-18-2012 17:09:51
Look on the mag it should have some info on it. There was 2 common mags used on the A/C tractors. So if you send me an e-mail and I send you the wrong one just let me know and I can send the other one.
jeff-h01
12-18-2012 18:07:39
 Re: Allis Chalmers b in reply to old, 12-18-2012 17:31:13
Sounds great...won't be able to untill tomm afternoon as it is at my dads...also what's a good asking price for one? It was a raffle tractor about 12 yrs ago complete restoration never been outside all tires are good really just needs washed also has cultivators on it...i was asking 1700...is that fair?
Ralphwd45
12-18-2012 19:03:10
 Re: Allis Chalmers b in reply to jeff-h01, 12-18-2012 18:07:39
Probably a Fairbanks Morse FMJ magnito, as these were the most common on a AC B or C tractor.To clean the points, remove the cap that has 2 screws, and take note of where the rotor bug is pointing at, then remove the 4 scrws holding the bakelite cap on.After exposing the points, go sneak the wife's sandpaper nail board, out of the house, and insert it between the closed points, and sand them shiney. Blow all sand out of the magnito, and reinstall the bakeite cap,MAKING SURE THAT THE ROTOR STILL POINTS WHERE IT DID PREVIOUSLY. This assumes that you didn't rotate the engine during the above actions. replace the cap with 2 screws, and try for fire. If no fire then your condenser or coil is bad, or the kill switch is grounded out. Good luck
jeff-h01
12-18-2012 19:14:21
 Re: Allis Chalmers b in reply to Ralphwd45, 12-18-2012 19:03:10
Now that u said it remember it saying Fairbanks Morris on it...i know about not turning the engine while apart...i have a Farmall f-12 and f-14i had to do work to..thanks for the help
