TractorLinks.com
Show Parts for Model:
Re: Coolant leak WD45
old
12-16-2012 15:51:16
First off drain the cooling system. Pull the hose off and then clean the hose inside and the water pump with carb cleaner spray. Let it dry a couple minutes then coat the inside of the hose with silicone sealer and install the hose and clamp it down good and tight. Walk away for at least and hour then fill the system up. Doing it that way lets the silicone dry and do its job. Also make 100% sure your leak is not a small hole in the hose or a cracked water pump
