WD-45 carburator
I have a marvel schebler TSX 871 carburator on a wd-45 Allis Chalmers, was not running very good,so took carburator off for a cleaning found the jet in bottom of bowl is not there(just the threaded hole).Tractor has been in family for 30+ years as it was my Dad's so I have no idea where it went , need to find new jet. Who would be most likely to have one? Good place to check would be appreciated.
Thanks
Best place to start would be an Agco dealer since they now own the A/C brand or tractor then go from there. This site may even have them
Try a good Napa auto parts store, they can get the rebuild kits mite be able to get more parts also.
TSX871 shows up as WD45, D15, D17 in a book I have - not sure if it was late WD45 or a replacement carb, but best source is probably someone who rebuilds carbs - there are several that sell parts as well as do repairs - Google Marvel Schebler - I think 1 is The Carburetor Doctor - also someone maybe on this or AC site that specializes in AC. I have used Matt at Motec Engineering for rebuilds with good results - he seems to have a lot of cores but not sure if he would sell parts.
All have given sound advice. If you check the AGCO web site:
http://agcopartsbooks.com/PartsBook...spx?book=agco/79001544&book=agco/79001544
Log on as Guest and search under AGCO Allis WD45. Two MS categories for WD45 lump TSX-561, TSX-464 & TSX-773 together while TSX-871 is listed separately, likely later engines. But it looks like the nozzle you want is common to them all and is AGCO part # 70226460, so it should be available.
If other sources don't have it, try Steve at 973-632-5596
