TractorLinks.com
Show Parts for Model:
Re: Allis Chalmers B Electric start conversion.
Bus Driver
12-12-2012 14:09:54
Does the engine block have the tapped bosses for the generator mount? Seems that I recall seeing some early Bs and/or Cs that did not have those bolt holes. And does it have hand brakes?
scatter
12-12-2012 14:17:58
 Re: Allis Chalmers B Electric start conversion. in reply to Bus Driver, 12-12-2012 14:09:54
I do not know about the bolt holes. The tractor has foot operated brakes. I wrote the serial number down when I went to look at it. Can't seem to locate it now. Which side of the engine would the generator mount?
steve(ill)
12-12-2012 18:24:32
 Re: Allis Chalmers B Electric start conversion. in reply to scatter, 12-12-2012 14:17:58
generator mounts to the left side, pulley in line with the fan belt. I have center punched the hole locations by comparing to another block, then drill and tap right thru the block. I loctite a stud in the two holes, and mount the generator bracket to it... no problem. YOu need a longer fan belt.
steve(ill)
12-12-2012 18:28:46
 Re: Allis Chalmers B Electric start conversion. in reply to steve(ill), 12-12-2012 18:24:32
as long as your at it, mount an alternator and 12 volt system.
1940 Orchard B, OB made from B Allis- now wiht FORD mower deck
bg/mo
12-12-2012 18:33:44
 Re: Allis Chalmers B Electric start conversion. in reply to steve(ill), 12-12-2012 18:28:46
Hey steve is that a home made IB?
bg/mo
12-12-2012 18:33:44
steve(ill)
12-14-2012 18:38:52
 Re: Allis Chalmers B Electric start conversion. in reply to bg/mo, 12-12-2012 18:33:44
the photo is a B that has the rear axle rotated 90 degrees and a straight front axle manufactured from stock. It has the B torque tube which is 6 inches longer than the IB, and it has B fenders. The IB had WD fenders. I made this 3-4 years ago and have a Bolten 6 ft belly mower deck on it now.
