TractorLinks.com
Show Parts for Model:
Re: cold starting D15 gas
wolfman
12-09-2012 17:38:28
Try this: When you shut it down, back off throttle to slightly more than idle. Next day when you want to start it - don't touch the throttle as that opens the govenor which will stall a cold gasser. Turn on the key, crank it and at first fire be ready to pull choke. Only touch the throttle if you're prepared to rechoke. After it runs a few seconds, then you can open it up to higher rpm. Don't forget, when you shut it down for the day to set the throttle where you want it tomorrow. ACs are about the best cold weather starters out there; there is a good chance you won't even have to choke it.
