TractorLinks.com
Show Parts for Model:
Re: what causes bad wobble if WD narrow front?
JMS/.MN
12-06-2012 21:57:15
Several causes- sloppy U-joint, worn pins, gears.....but don't ignore the big bearing on the bottom of the pedestal...They typically 'scallop' out- they don't turn much, but get hammered with constant pounding of the front wheels against the ground. Higher speeds, more wobbling. Pull that lower bearing, look for flat spots.
bg/mo
12-07-2012 07:58:26
 Re: what causes bad wobble if WD narrow front? in reply to JMS/.MN, 12-06-2012 21:57:15
It seems to me the last one that I replaced, whe the bearing supply looked up the number on that bearing it is supposed to be rounded almost barrel shaped on the rollers in the bearing. caused they crossed that number to a regular tapered roller bearing.
