Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Warning--pulling engine on WD45
JMS/.MN
12-04-2012 15:19:32
All you have to do to get the engine out is remove the radiator, take out the cotter key by the spring on the hand crank shaft, and remove the bolt that hold the bracket there. Shove that shaft forward into the steering housing. Remove the front engine support after the engine is on the hoist, then 4 bolts at the bell housing, plus the sheet metal flywheel cover. Gives you have plenty of room to remove the engine. Removing side rail, steering knuckle, anything else....simply not necessary.
Copyright © 1997-2015 Yesterday's Tractor Co.
