Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Allis C front end
Zachary Hoyt
12-02-2012 18:33:41
I am wondering what the rod behind the seat on the C is for, if it was part of the cultivator or something. I have never seen a Monroe seat with the spring pointing up like that, but it seems to be the way it was made from what I have found online. I am going to put the radiator from the B on the C since the C engine is ready to run and the B engine has a big hole in the block. Then I will part out the rest of the B. Zach
12-03-2012 18:23:45
 Re: Allis C front end in reply to Zachary Hoyt, 12-02-2012 18:33:41
THe bar behind the seat is called the rock shaft. It normally has two arms attached to it. Serves the same purpose as the lifting arms on a 3 point hitch. ON the Allis, you pin the plow, disc, blade under the transmission, and the two arms on the rock shaft "lift" the attachement when connected to a cylinder.
12-03-2012 18:26:54
 Re: Allis C front end in reply to steve(ill), 12-03-2012 18:23:45;//
Zachary Hoyt
12-04-2012 15:37:25
 Re: Allis C front end in reply to steve(ill), 12-03-2012 18:26:54
Thanks, that makes sense now that you have explained it.
