Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: How to determine which steering gear (pic)
Bobby 9891
12-02-2012 16:26:12
Thanks Dick - I guess my boy & I will tear it apart this coming Sat.Any more advice before I attempt this & what happens when I pull that end plate off ? What does the follower look like & will it come out easily ? I pulled the starter off today to get at the adjusting screw but it was screwed all the way in should I back it out some & try removing some of the shims where the jacket tube goes into the box ??
Dick L
12-03-2012 02:26:05
 Re: How to determine which steering gear (pic) in reply to Bobby 9891, 12-02-2012 16:26:12
At the link I have placed below you can see my repair of one. Click on the picture to advance to the next picture or (next) at the top.
Bobby 9891
12-03-2012 04:24:01
 Re: How to determine which steering gear (pic) in reply to Dick L, 12-03-2012 02:26:05
Is that short pin the follower ? Thanks for the pictures !!
Bobby 9891
12-03-2012 11:09:22
 Re: How to determine which steering gear (pic) in reply to Bobby 9891, 12-03-2012 04:24:01
Oh gosh I bet that is very hard steel !!! Thats proably why the guy before me didn't fix it. Whats the prodecure for this - cut it off first ?
Dick L
12-03-2012 14:34:49
 Re: How to determine which steering gear (pic) in reply to Bobby 9891, 12-03-2012 11:09:22
Not hard at all. I grind them off with an angle grinder, find the center and drill thru. I make my own pawl with 3/8 inch for a press fit and don't weld it in. Once it gets put back together it has no way of getting out even if it might be a tad loose with a slip fit.I do not know what the pin diameter of the ones you get at John Deere. I see over the years that most think it needs welded in. To each his own.
Bobby 9891
12-04-2012 09:12:02
 Re: How to determine which steering gear (pic) in reply to Dick L, 12-03-2012 14:34:49
Thanks Dick - I hope this is my problem. How long do you think it will take to tear down & put back after I change the pawl ?
Bobby 9891
12-04-2012 18:31:57
 Re: How to determine which steering gear (pic) in reply to Bobby 9891, 12-04-2012 09:12:02
Thanks Dick- If the pawl isn't flat on both sides where would I look for another problem ? The tie rods have some play but it doesn't seem to be excessive. I called the JD place today but they wern't sure what I was needing. They had heard of a pawl but wasn't sure of what it was . I told them I would bring a pic of it - maybe they can figure it out !!
Dick L
12-04-2012 12:52:09
I swapped one out for a fellow at his place one time in a forenoon. I think it was about three hours. I had all my tools that I would need on the truck. Not my first dance though.
I also swapped out his tie rod in that time.
Bobby 9891
12-05-2012 10:04:03
 Re: How to determine which steering gear (pic) in reply to Dick L, 12-04-2012 12:52:09
Dick, do you know where I can get a part # for the pawl in that Ross gear box ? Went to the local JD dealer but they had know info without a part # to stsrt with !
Bobby 9891
12-05-2012 11:26:06
 Re: How to determine which steering gear (pic) in reply to Bobby 9891, 12-05-2012 10:04:03
Dick I found the part # for the follower or pawl for the ross steering box .
Dick L
12-03-2012 05:02:50
That is what some have called it. It has other names with different people. Pawl is what I call them. They tell me you can buy the pawl at the John Deere parts counter. You have to drill out the old one.
