Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: WD oil pressure issue
Tristan in MN
11-22-2012 13:55:41
I checked the number on the filter, its 7011. I remember there being a tube sticking up when i put the filter on. I may just have to try another filter.
11-23-2012 19:30:08
 Re: WD oil pressure issue in reply to Tristan in MN, 11-22-2012 13:55:41
the wix filter 57011 and the napa filter 7011 are both made by wix. if you have any wix number then delete the first number and you have the napa number the oil pressure is dependent on the filter restriction. higher the restriction the higher the pressure. you could disconnect the feeder line to the filter and install a meter to the line and get a lot more realistic number of output but still may go to zero when running the filter if not correct.
11-22-2012 14:05:06
Ya the incorrect filter will cause you to buy a new engine or rebuild the one you have. Many filters will fit but many are the paper type that have no back pressure to them so you then have little or no pressure and no pressure equals lack of engine oling
