(quoted from post at 11:15:15 11/20/12) Sealed or "lubed for life" if they need lube their
life is about over, time for new ones.
(quoted from post at 13:04:32 11/20/12) Shealray,
Liquid grease spray will work it's way out as easily as it worked it's way in unless you apply it regularly. Plan to remove the bearings. You can repack them again by hand. I've done many of them by popping out the seals using a seal pick. This can be done without damaging the seal so it can be reused. Many of these bearings still contain a small amount of grease so clean them well. After cleaning check by feeling for abnormal bearing surfaces and sound. If all is well you will get a lot more life from them.
Joe
(quoted from post at 13:40:40 11/20/12) That rake is much newer than the 40s. AC had the pto side delivery rake before they made this one, a parallel bar style. The Model 77 style was first introduced in 1958, and the Model 78 made from 1965-70. 78 had the sealed bearings, don't know about the 77.
