Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 185 lift arm cylinder
Eldon (WA)
11-19-2012 20:41:11
Oops, I see you were on the RH side, that shouldn't be as bad as the LH side....under the oil leaks and no hydraulic lines underneath....
11-20-2012 03:36:02
 Re: 185 lift arm cylinder in reply to Eldon (WA), 11-19-2012 20:41:11
Thanks Eldon, appreciate yours and Bob's advice. Turns out that the spring pin was sheared off long time ago and the main pin had moved so that I could not see the spring pin hole and the main pin was rusted hard in there. Here's a picture of the final mess after I had to apply heat. Brake cleaner also worked wonders to flush the pin out while moving it back and forth in the hole. (brake cleaner and heat not at the same time of course).
