Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: tricycle front wobble
Lonnie Smith
11-19-2012 18:41:16
You need to narrow it down a little more. Play could be coming from the steering gear box, one of the tie rod ends or in the front pedestal. How much can you turn the steering wheel without the tires moving and where is the excess movement at?
Bobby 9891
11-20-2012 06:42:30
 Re: tricycle front wobble in reply to Lonnie Smith, 11-19-2012 18:41:16
Theres lots of play in the steering wheel- it can be moved alot before the wheel moves.
acken fromwisc
11-20-2012 08:09:13
 Re: tricycle front wobble in reply to Bobby 9891, 11-20-2012 06:42:30
The steering gearbox under the gas tank needs adjustment. should be a screw with a lock nut on it.
Bobby 9891
11-20-2012 08:46:37
 Re: tricycle front wobble in reply to acken fromwisc, 11-20-2012 08:09:13
OK-so how do I get to this screw & locknut ?
Lonnie Smith
11-20-2012 14:00:41
 Re: tricycle front wobble in reply to Bobby 9891, 11-20-2012 08:46:37
There are holes in the sides of the tool box where you should be able to get to them.
Bobby 9891
11-20-2012 15:07:23
 Re: tricycle front wobble in reply to Lonnie Smith, 11-20-2012 14:00:41
So you think its in the box & not the pedestal? It even wobbles @ slow speed. Looks like I might need to pull the sheet metal off around the box. I sure hate to mess up the paint but I've got to get this fixed.
Dick L
11-20-2012 16:26:41
 Re: tricycle front wobble in reply to Bobby 9891, 11-20-2012 15:07:23
The adjustment screw would be behind the starter. You would need to remove the starer to get at it. Chances are that it is a Ross which would most likely need inside repair. A Gemmer normally will not give a great deal of play compared to the Ross. I have pictures of both laid out in pieces if interested.
