Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: allis wd what to look for
11-18-2012 18:22:08
One way to handle the lower pin removal is to drill a 3/4 inch hole in a short length of flat iron, weld it to the pin. Heat of welding helps to loosen pin, as does adding candle wax to the pin as it cools. Use the flat iron as a handle to wiggle the pin loose. If you're careful, grind off the weld and re-use the pin, using Never-Seize upon re-installation.
