| Allis Chalmers Discussion Forum |
Topic: wd45
[Return to Forum]
| Author |
[Modern View]
| Butch WI
11-17-2012 11:21:26
107.26.89.194
Going to try to rebuild a carb on my MIL wd45. have the old one in pieces (taken apart by one son 8 years ago) the rebuild kit is here for it. It is a Marvel Schebler TSX. Any one got any tips?? Also I beleive it is a 6V system also. The battery is no where to be found and my question is will it run with out one if I am trying to pull start it? I will put fresh gas in it (provided I am succesful at the carb rebuild. I do have the instruction sheet fron Zenith Fuel Systems, so that should help.
Any comments would be appreciated. |
| Matt Reinders
12-09-2012 13:27:57
71.10.127.31
Re: wd45 in reply to Butch WI, 11-17-2012 11:21:26
| Go to the URL I listed. They have videos on how to tune up your tractor. I use them for the restoration class I teach. |
| Matt Reinders
12-09-2012 13:30:00
71.10.127.31
Re: wd45 in reply to Matt Reinders, 12-09-2012 13:27:57
| If you just search j and d productions you will find the website |
| Aaron SEIA
11-19-2012 04:56:20
67.55.181.57
| WD45 was factory dist ignition.
AaronSEIA |
| Bob Huntress
11-19-2012 19:40:40
98.66.42.12
Re: wd45 in reply to Aaron SEIA, 11-19-2012 04:56:20
| Some (even most) were factory distributor, while some were Fairbank Morse magneto. |
| Butch WI
11-18-2012 17:06:08
184.63.239.168
| Well guys I had gotten stumped by the carb so I am taking it to a friend who has a little more experience with them. As far as the 12V battery , I was able to hook one up and she cranked over so now I just need a fuel supply. Thanks for your help. |
| Bob Huntress
11-19-2012 00:10:08
184.41.92.132
Re: wd45 in reply to Butch WI, 11-18-2012 17:06:08
| Butch, does your WD45 have distributor or magneto? If magneto, it won't matter whether you have a battery hooked up. The WD45 would have a Fairbanks Morse magneto, if it is magneto. If you have a magneto, and are considering a 12 volt conversion, you may wish to only convert the starting circuit, charging circuit and acs. circuits (lights etc). You don't have to change anything in the ignition circuit if you have a magneto and like it that way. |
| LeonardWD45
11-17-2012 12:47:55
132.3.65.68
| | Butch, make sure that you clean all the orifices in the carb. Also make sure that the tank and fuel line is clean. With the electrical, my WD45 is converted to 12v system and I have a ballast resister inline from the battery to the coil, still use the 6v coil. It is a very simple proceedure to change the system over. if you search here on this site you will come up with diagrams on how to do it. BTW you will not be diaspointed if you choose to convert to 12v. Much easier to start and you have common batteries through out your fleet of equipment. Leonard |
| Aaron SEIA
11-17-2012 11:58:45
208.126.88.85
| Wouldn't he need a 12v coil? I'm far from an expert on ignition systems, but since a WD45 was originally 6v + ground and had a dist, you would need to know what battery was in it last to know what it'd need now.
AaronSEIA |
| old
11-17-2012 17:23:40
209.86.226.32
Re: wd45 in reply to Aaron SEIA, 11-17-2012 11:58:45
| You can use a 12 volt battery to get one up and running then us a 6 volt battery there after. Done many of them that way and if you run them for say 30 minutes or so you will not hurt much of any thing. Ya the points would not last as long but just for getting it running 12 volts is ok then go back to the 6 volt after you know it runs ok |
| old
11-17-2012 11:33:23
209.86.226.40
| Not likely to ruin with out a battery since it stands about a 99% chance it has a battery ignition. Just for starting it and doing the get it running stuff you can use a 12 volt battery + ground and not hurt a thing as long as you do not run it for hours at a time or leave the ignition turned on |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
