D-17 coil replacement
This is a follow up from an earlier post on my tractor not running well..If I get a new coil with the built in 3 ohm resistor. Do I still need the external resistor that is on the tractor now, between the coil and Distributer ??
Thanks
I assume your tractor is 12 volt negative ground. If so you do not need an external resister if you use a 12 volt coil with 3 ohm resistance.
