Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Cant get head off of WD??
[Return to Forum]
johndeerefan85
11-14-2012 17:33:09
173.25.53.6
Iv got a WD im working on and have ran into a little bit of a problem.I pulled the vavle rocker shaft,took all the bolts out,removed the manifold,and the water pipe.Iv tapped on the side of the head and tried prying on it a bit and it wont move at all..Any suggestions?
[Reply]   [No Email]
Lee231
11-15-2012 14:24:16
66.87.4.35
 Re: Cant get head off of WD?? in reply to johndeerefan85, 11-14-2012 17:33:09
Had a head I couldn"t get off once. I had to hook it up to an engine hoist, had the tractor front off the ground and still wouldn"t come loose, ended up using a rose bud playing along the top of the head and when it got nice and warm it popped loose. Turned it was put on with permatex. HTH"s. Lee
[Reply]  [No Email]
WEL
11-15-2012 14:15:32
216.8.200.232
A pipe in the manifold hole has always worked for me. Use common sense when doing this as not to damage anything.
[Reply]  [No Email]
BushogPapa
11-15-2012 07:50:25
173.88.51.117
We had an old Ford truck with a Flathead V-8 and it needed re-built...
Dad took all the head bolts out and the heads would not come off..I guess they had been "Permatexed"..
He drove it up and down the road with the head bolts all loose and they never did come off..
Scrapped that engine...
"I am not a fan of Permatex"..!!!
Ron..
[Reply]  [No Email]
rustyfarmall
11-15-2012 06:55:35
216.248.71.226
 Re: Cant get head off of WD?? in reply to JMS/.MN, 11-14-2012 17:33:09
You've already got the manifold off. Stick a pry bar into one of the exhaust ports in the head and lift. I usually use my 1/2" drive breaker bar.
If that doesn't work, put the spark plugs back in and then bump the starter. Forget filling the cylinders with oil. The compression alone should do the trick.
[Reply]  [No Email]
Diydave
11-15-2012 04:59:35
96.244.157.254
For safety sake, if you do use the starter to pop the head off, put some bolts in the head, loosely. You don't have to use the head bolts, but put some in that are of similar length, leave about 1/4" loose. That way when the head pups off, it doesn't slide to the side, and land on the floor!
[Reply]  [No Email]
Will Herring
11-14-2012 20:01:53
50.103.252.25
 Re: Cant get head off of WD?? in reply to old, 11-14-2012 17:33:09
No danger of mucking up rods or pistons doing this if she won't give? Wouldn't it be better to spin her with the hand crank to keep the spin slow if you did this? Just curious.
I figure the issue is that the old head gasket has become like a super bond between the head and the block. I had the same problem taking an old carb off my WD. Basically had to use a block of wood so I could hit the top side with a hammer to knock the carb off -- and it was just a small, old paper gasket that had fused the two pieces of metal together.
[Reply]  [No Email]
old
11-15-2012 07:50:54
209.86.226.40
 Re: Cant get head off of WD?? in reply to Will Herring, 11-14-2012 20:01:53
With the cylinders filled with oil the starter can not produce enough torque to hurt any of the engine parts due to the fact it does not get up to full speed before it hits the hyd lock so it safe for popping a head off
[Reply]  [No Email]
Guyzoo
11-14-2012 19:38:02
47.54.102.253
if you removed all the bolts(including the three 3/8'' ones then maybe try to pry it with something or try to inert something between head and block into the head gasket being careful not to damage machined surfaces. maybe someone in the past used sealant on the head gasket
[Reply]  [No Email]
Aaron SEIA
11-14-2012 18:19:57
67.55.181.57
If you are positive you have all the bolts out, then pry harder. It can take some real brute force to pop them loose. I wonder if you could pull the #1 or 4 plug and chuck up an air compressor and see if that'd pop one end loose.
AaronSEIA
[Reply]  [No Email]
RALPH 1111
11-14-2012 18:04:14
204.12.181.71
OLD Would water in place of oil???????
Seames like it would make less of a mess.
[Reply]  [No Email]
old
11-14-2012 18:45:38
209.86.226.56
 Re: Cant get head off of WD?? in reply to RALPH 1111, 11-14-2012 18:04:14
Problem with water is rust and the one thing you do not want in an engine is rust and if the head did not come off then you have water in it and no way to get all the water out. Now if you had said fill the cylinders with a small diameter rope that will also work
[Reply]  [No Email]
old
11-14-2012 17:55:02
209.86.226.56
If your not worried about making a mess then do this and it will work. Fill the cylinders with oil put the plugs back in and then use the starter to spin it over. The head then has to move due to the hyd effect
[Reply]  [No Email]
Uncle Ernie
11-16-2012 03:48:58
64.38.158.247
 Re: Cant get head off of WD?? in reply to old, 11-14-2012 17:55:02
Forget water or oil. Feed a piece of rope in thru a spark plug hole and let it pile up on top the piston. Then roll it over until the piston pushes the rope against the head. Way better than a liquid!
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
