| Allis Chalmers Discussion Forum |
Topic: AC C piston ring orientation
[Return to Forum]
| Author |
[Modern View]
| Noah in IA
11-11-2012 07:52:46
166.181.3.205
Hey guys,Just a quick question here since my service manual makes no mention of it; do I need to position the piston rings in any specific manner (like an angular offset between ring gaps) before installing into the sleeves? Also, what specific surfaces do you coat with assembly lube before install? As I"ve mentioned before, I"m new to this engine/mechanic"n stuff so your help is much appreciated! Thanks, |
| old
11-11-2012 12:29:51
209.86.226.40
Re: AC C piston ring orientation in reply to Noah in IA, 11-11-2012 07:52:46
| When I do rings I always line them up 180 out. If you have a 3 ring piston you do the oil or bottom ring one way then the next up 180 out and then the next/top 180 out. You can always do them so they are 1/3 of the way around from each other |
| Orange Fever
11-11-2012 09:57:27
208.126.198.205
| | You don"t need to aline in an specific order. Just remember you never align them all in the same spot. This would cause blow by and oil cunsumption problems. What i do is offset the ring gap by 3rds or 180 degrees from one another. The oil ring scraper I place one at 10 o"clock above the wrist pin and the other at 4 o"clock below the wrist pin. There should also be instructions on which side of the ring faces up. As for assembly lube i use whichever weight of oil I"m running in the crankcase for assembly. Set your rings in a bowl of oil before you place them on your pistons. Oil the gland that the rings are to be install in on the piston. oil the inside of your piston sleeves before placing your piston into them. oil the wrist pin and where the rod connects to the wrist pin. Need less to say just oil everything, no oil will cause damage when you start the engine. I even place a little oil on top of piston for more lubercation when starting. So with all this oil just make sure your deck is oil free and dry for your head gasket to seal. |
| BushogPapa
11-11-2012 12:46:40
173.88.51.117
Re: AC C piston ring orientation in reply to Orange Fever, 11-11-2012 09:57:27
| I like to orient the end-gaps somewhat over opposite wrist-pin ends..staggering a rather small amount.. Ron.. |
| rustred
11-11-2012 14:29:25
72.172.100.113
Re: AC C piston ring orientation in reply to BushogPapa, 11-11-2012 12:46:40
| yep thats the way i do it. keeping the gaps towards wrist pin area and out of the major and minor thrust area of piston. |
| Noah in IA
11-11-2012 17:07:32
166.181.3.92
Re: AC C piston ring orientation in reply to rustred, 11-11-2012 14:29:25
| thanks guys - that's the info i was looking for! |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
