TractorLinks.com
Show Parts for Model:
Re: D-17 coil replacement
WEL
11-11-2012 04:35:15
I assume your tractor is 12 volt negative ground. If so you do not need an external resister if you use a 12 volt coil with 3 ohm resistance.
Dave DelDebbio
11-11-2012 05:12:50
 Re: D-17 coil replacement in reply to WEL, 11-11-2012 04:35:15
Yes, it is 12V neg ground. They have a good price for one on this site, so I can get it and eliminate 2 possiable issues.
Thanks
steve(ill)
11-11-2012 06:26:03
 Re: D-17 coil replacement in reply to Dave DelDebbio, 11-11-2012 05:12:50
YES... the external resistor is only used if you keep the old 6 volt coil.
Dave DelDebbio
11-16-2012 10:51:27
 Re: D-17 coil replacement in reply to steve(ill), 11-11-2012 06:26:03
If I do not end up getting a 12v coil with the built in resistor, then would I need to keep the external one ?
