Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Allis Chalmers 5' Rotary Mower Gear Box Oil?
[Return to Forum]
Will Herring
11-10-2012 14:14:47
50.103.230.183
I am going to check the oil in my gear box tomorrow, and wondered what weight oil it takes. I assume it is 90 wt gear oil? The plug is right there above the old "AC" logo.
Also, can anybody tell me what model this is, so I can try to find a manual for it? It's a recent acquire, and I don't know much about it.
[Reply]   [No Email]
Will Herring
11-11-2012 12:53:44
50.103.230.183
 Re: Allis Chalmers 5' Rotary Mower Gear Box Oil? in reply to Tim(nj), 11-10-2012 14:14:47
Put a quart of 85w140 in (as it was all I could find around here)... Found it took the first pint without pushing anything out the level plug on the other side. Finally she started to let some "goop" out. I'm glad I topped her off... I kept adding it until what was coming out the level plug looked halfway decent. Mower ran good afterwards, too.
[Reply]  [No Email]
Will Herring
11-10-2012 18:03:45
50.103.230.183
 Re: Allis Chalmers 5' Rotary Mower Gear Box Oil? in reply to chevytaHOE5674, 11-10-2012 14:14:47
Oops, I forgot to ask if I needed to grease anything else. Also good to know; will hit that with a few squeezes of grease as well.
[Reply]  [No Email]
Will Herring
11-10-2012 18:02:28
50.103.230.183
 Re: Allis Chalmers 5' Rotary Mower Gear Box Oil? in reply to DRL, 11-10-2012 14:14:47
Whew, good to know! Will definitely be doing this tomorrow.
[Reply]  [No Email]
wolfman
11-10-2012 17:25:07
174.140.65.158
 Re: Allis Chalmers 5' Rotary Mower Gear Box Oil? in reply to Will Herring, 11-10-2012 14:14:47
Will, There are two plugs; the one on the right
side is the fill plug, the one on the left side is
the level plug. Left one is lower; fill right plug
til it starts to run out the left plug. Very good
mower. Made for AC by Brillion (I think).
[Reply]  [No Email]
wolfman
11-10-2012 17:25:07
174.140.65.158
[Reply]  [No Email]
Diydave
11-11-2012 04:51:07
96.244.153.238
 Re: Allis Chalmers 5' Rotary Mower Gear Box Oil? in reply to wolfman, 11-10-2012 17:25:07
The early 60" mowers were made by danuser, not brillion. This one is a laporte built model.
[Reply]  [No Email]
Diydave
11-10-2012 17:25:05
96.244.153.238
It's a pull type AC 160, those wheels can be flipped 180 degrees,
and moved inboard, if you don't want to leave tracks. I use 90W140
in mine, no problem. There is also a grease fitting, below the gear
box, in the back, to lube the 2 lower bearings.
[Reply]  [No Email]
Will Herring
11-10-2012 14:44:42
50.103.230.183
 Re: Allis Chalmers 5' Rotary Mower Gear Box Oil? in reply to BushogPapa, 11-10-2012 14:14:47
Jerry Coulter said: (quoted from post at 18:40:03 11/10/12) You have the model 160-T 5' trailer mower. I have a model 172-M 6' 3point mounted mower. My manual covers both models. It says the gear box takes 3 1/2 pints of SAE 140.
SAE 140? Wow. Would not have expected that.
I assume you just fill it to the top of that fill port on the side of the gear box housing?
Also, thank you for the implement ID. Didn't look quite like the other 160s I have seen -- it seems much bigger from front to back than the others.
This post was edited by Will Herring at 14:47:00 11/10/12.
[Reply]  [No Email]
maxwell99
11-10-2012 14:43:28
208.92.110.81
You can always use Jd or case ih. cornhead grease. This lube
is almost like gear oil, but much better lube material.
[Reply]  [No Email]
Jerry Coulter
11-10-2012 14:40:03
50.40.165.22
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
