| Allis Chalmers Discussion Forum |
Topic: WD45 overcenter clutch
[Return to Forum]
| Author |
[Modern View]
| Ralphwd45
11-06-2012 12:34:59
66.243.215.161
4 yrs ago I split the tractor, and installed a new clutch in it. I put the 3/32" (or thereabouts) shims back in it, that were originaly there. After trying it out, it had excessive creep, in gear with the clutch released and I didn't like that, so I opened it up again, and added a .010 shim to all 3 points, closed it back up, and still had some creep, but it was better. Now the handle falls out of engagement, at the worst times, like loading manure on a slick surface, when stopping momentarily, means being stuck. I opened it up yesterday and pulled the 3 .010 shims out, and went back to work. It still falls foreward at times, and is only a little bit better.When I read about removing the shims to get more life from the clutch, does that mean that I should remove the 3 thick shims? Will the clutch still work, with those removed? |
| stu (ON)
11-06-2012 17:27:10
70.27.27.116
Re: WD45 overcenter clutch in reply to Ralphwd45, 11-06-2012 12:34:59
| Leonard, if you still have the original shim packs in place, examine them very closely to see the individual shims. They are very thin and become very compressed over the decades. It may require a razor to separate them.
The service manual calls for a 0.065" clearance between the clutch plates at all points around the discs. This can be measured with a drill bit as a gauge.
The manual instructs to keep the clutch engaged when not in use to keep the oil squeezed from between the plates and minimize drag when the 80W oil is cold. Since the WD45 squeezes three pairs of plates in the space that the WD had only two, it is common to find the drag with high viscosity or cold oil. |
| JMS/.MN
11-06-2012 15:56:11
209.237.125.241
| To adjust the clutch you remove as many shims as required to get the clutch to have a definite "snap" over center. Some creep is almost normal, especially when the oil is cold. |
| LeonardWD45
11-06-2012 14:53:19
131.191.110.118
| | Ralph, if you call Walter Implement, 509 982 2644, in Odessa they are available and can order them. Part numbers are 224542 or 226691. Ask for parts. Leonard |
| LeonardWD45
11-06-2012 13:19:21
131.191.110.118
| | Ralph, in the manual there is a measurement that is supposed to be maintained for the slip clutch. I don't have my book here or I would give you the measurement. Yes you can remove shims to fix the problem. BTW the shims at each location should be stacked so you can adjust the measurement. Leonard |
| Ralphwd45
11-06-2012 13:46:02
66.243.215.161
Re: WD45 overcenter clutch in reply to LeonardWD45, 11-06-2012 13:19:21
| Leonard! where can I obtain shimms that I can stack, with the proper holes to fit? the 3 shims I made out of .010 stock, had rough edges to the sides, and holes. metal shears, and hole punches are not kind to shim stock! |
| Ralphwd45
11-06-2012 13:45:02
66.243.215.161
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
