TractorLinks.com
Show Parts for Model:
Re: D-17 Not running well
DonBC
11-04-2012 11:15:37
It might be ignition related. My D grader that has the same engine had a similar problem. It would start and run fine but after a while it would start miss firing as if it was not getting enough fuel. I blamed the problem on a fuel problem and did all the things that you did. Finally I found that the coil would heat up after a while and it would start to miss fire. I replaced the coil and solved the problem.
Dave Deldebbio
11-04-2012 13:49:41
 Re: D-17 Not running well in reply to DonBC, 11-04-2012 11:15:37
Thanks, if the carb re-cleaning dont work, that was my next guess. I replaced the points, rotor & cap a few years ago so they should be OK, ( at least I know there not original parts ) There is a resistor between my coil and distributor . Is there a certain type of coil I need to get ? 12 or 6 volt ? Thanks..
