Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: D-17 Not running well
11-03-2012 09:32:15
Almost no way to install the gasket wrong and have all the bolt holes line up. First thing to check believe it or not do so any how is your spark. Make sure it is a blue/white in color and will jump a 1/4 inch gap at ALL 4 plug wires. Weak spark will make it so you have to have an extra rich mixture to burn well if at all. If your spark is good then check your air cleaner and make sure it has the right amount of oil and not full of dirt/water. As for the carb when you had it open did you spray out ALL the passage ways with carb cleaner and did you also poke a small wire I use a torch tip cleaner tool into all the passage ways so as to make sure they are clear and open
Dave DelDebbio
11-03-2012 15:33:34
 Re: D-17 Not running well in reply to old, 11-03-2012 09:32:15
Ok, thanks everyone, here's what Ive done. Replaced pluges, checked spark at plugs and at distributor cap,Looked real good. I have checked the air intake system, thats good. We Had it running real good for a while this eve, then all of a sudden it just starts acting like it's starving for gas. We tweek the jets a little, it straightens out for a while, then acts up again. Im taking the carb off again to give it it a good going over. Will let ya know happens next. Thanks
Dave DelDebbio
11-04-2012 03:41:26
 Re: D-17 Not running well in reply to Dave DelDebbio, 11-03-2012 15:33:34
Just an FYI to all who have helped. I will be going out of town for the week ,so if I dont get the carb on this morn, it will be next Sat before I can give it the test Thanks again..
