| Allis Chalmers Discussion Forum |
Topic: Propane carb
[Return to Forum]
| Author |
[Modern View]
| Bruce Bushnell
11-01-2012 18:59:13
64.254.48.127
I have wd that runs on propane. I have a another wd that was on gas, but engine is stuck, but in overall better condition than the propane. I want to change the engines. Did Allis have a carb that would run gas and propane? I would like to keep the gas tank in present location and put the propane tank out front. |
[Reply] [No Email] | |
| michael crowe
11-13-2012 09:21:23
70.252.144.30
Re: Propane carb in reply to Bruce Bushnell, 11-01-2012 18:59:13
| The Ensign carburetor for the dual fuel WD / WD45 was a model number KnG1 or KgN1, I can"t remember. From what I have learned and my literature, the WD never came from the factory as a dual fuel, but you could get a kit and retrofit it. The 45 could be ordered as a dual fuel from the factory. Both use the same model carbretor, but AC listed different part numbers so there must have been some internal difference. I have a couple extra carburetors and regulators for these tractors, but I don"t part with them until I get my WD and WD45 dual fuel tractors all rebuilt and running. |
| smonell
11-02-2012 20:41:07
173.184.54.200
| Original factory dual fuel is an Ensign, an aftermarket propane adapter choice of the time was to drill and tap a 3/8" PT hole in the bottom of a Marvel Schebler carb and screw the propane injector into it which was attached to a regulator, filter, and front mount tank. The tank was similar, but not the same as the factory dual fuel tank. You could run on gasoline or propane by shutting off supply. I have both if you want photos. |
| David R Inman
11-02-2012 12:17:30
150.135.210.59
| | Most claim the WD did not come with the "duel fule" Ensign Gasoline/ LPG carb. However, the WD/WD45 parts book lists 70226076 as the Carburetor, combination (ensign no 2554) as for the WD, and 70226714 as the Carburetor, combination (Ensign no. 3060) See link. Now, from what I"ve seen, to find either of the ensign cabs listed, you will likely need to part with a large part of your wallet. And even if you do manage to find one, no one on this form seams to know what to do if you need to rebuild it. Search the archives of the allis board here for Ensign MG1 and you will find some about the Ensign carb we have with a WD45. I didn"t re read what is posted there, but if the LP carb you have is stamped MG1 where it bolts to the manifold, it is the same LP carb as used on the D series AC"s. Hope that helps you some. |
| Bruce Bushnell
11-02-2012 15:49:36
64.254.48.127
Re: Propane carb in reply to David R Inman, 11-02-2012 12:17:30
|   These are pictures of the tractors. The propane tractor has an ensign carb. Couldn't see any no. on it. Curious about connection on bottom. Copper tubing coming out of it |
| Bruce Bushnell
11-02-2012 15:45:58
64.254.48.127
| Bruce Bushnell
11-02-2012 15:54:55
64.254.48.127
Re: Propane carb in reply to Bruce Bushnell, 11-02-2012 15:45:58
|  Picure there now? |
| Jerry Coulter
11-02-2012 18:22:27
50.40.165.22
Re: Propane carb in reply to Bruce Bushnell, 11-02-2012 15:54:55
| The propane tractor has an after-market conversion. The copper tube coming off the carburetor top supplies vacuum to the fuel valve which shuts off fuel when engine is stopped. You should have to momentarily hold a bleeder valve open to provide fuel to start the engine. |
| Jerry Coulter
11-02-2012 11:01:32
50.40.165.22
| The factory WD45 LPG model had a dual fuel carburetor fed from either a propane tank mounted in front or ethyl gas from the bullet tank. I think the carburetor was an Ensign. |
| David R Inman
11-02-2012 20:45:33
150.135.210.73
Re: Propane carb in reply to Jerry Coulter, 11-02-2012 11:01:32
| Agreed- after market. On the ensign MG1 carb we have, the model is stamped on the face so that it can only be found by separating the carb from the manifold. By looks, I'd guess your carb is also an MG1, or very similar ensign model. |
| BushogPapa
11-01-2012 19:21:56
173.88.51.117
| You can use the Gas engine with your Propane Carb.. Propane engines usually have a little more compression than Gas, but it will run fine.. I do not think AC ever considered "Dual-Fuel" use, back in those days.. Ron |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
