| Allis Chalmers Discussion Forum |
Topic: Re: Head Gasket
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| BushogPapa
10-27-2012 10:36:19
173.88.51.117
Replace the radiator hoses while it is apart..!! Pretty straight forward.. about the only problem I have had is getting the plate between the 2 rear head bolts to seal.. Use some sealer on the Push-rod side of the head gasket..they seem to seep on that side for a while if you don't.. Might be a good idea to knock a freeze plug of two out and Flush the water jacket out while you can. Ron.. |
| BushogPapa
10-29-2012 10:20:33
173.88.51.117
Re: Head Gasket in reply to BushogPapa, 10-27-2012 10:36:19
| NO, you do NOT need to pull the engine for a Head Gasket... You WILL need to remove the top sheet metal "Hood".. That comes off easy, with a few screws up near the radiator and the "Screw-clamp" around the gas tank.. Lift off the air inlet cover and the hood will lift off.. After that, it is a straight-forward head Gasket change.. If you ever want a new muffler, remember, ONLY a "Nelson" Muffler sounds "Correct".. Ron.. |
| BushogPapa
10-29-2012 10:19:53
173.88.51.117
| Country Bob 74
10-29-2012 05:14:23
198.248.149.13
| Will I need to pull the engine to replace the head gasket? |
| BushogPapa
10-28-2012 16:56:49
173.88.51.117
| When installing the Int/Exh manifold, I rub Hi-Temp Silicone into the white rings, slip them on the manifold runners, stick the metal cups on them, then slip the manifold in place..keeps everything together better..!! I think it makes the gaskets last longer too.. Use "Never-Seize" on the Manifold nuts.. I like to add a Hardened Washer under each nut.. Might as well check or replace the thermostat while you have it apart.. Ron.. |
| Country Bob 74
10-28-2012 13:54:41
216.183.205.20
| Thanks so much, can use all the help I can get. I'm not much of a mechanic. |
| Country Bob 74
10-28-2012 13:54:41
216.183.205.20
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
