TractorLinks.com
Show Parts for Model:
Re: Three different WD plows -- need some information...
Will Herring
10-26-2012 18:39:16
Jerry Coulter said: (quoted from post at 21:31:15 10/26/12)
For the hydraulic pull plow, the only one of those I remember had no tail wheel, rather had an adjustable chain hooked from the beam to the tongue which may be hooked too short.
The two bottom one I've got has the wheels mostly across from each other (I think the right side or furrow wheel is a bit "forward" of the left side or land wheel). Facing from the rear of the plow to the front, there is a lever on the right side that pulls the right rear wheel "up" (to set depth for that side?), and then there's a chain that goes from over on the left to the hitch. Hydraulic cylinder will lift the plow, but I've got it not quite set right -- you have to put extra weight on the back to get it to "drop in", so to speak.
This post was edited by Will Herring at 18:40:26 10/26/12.
