TractorLinks.com
Show Parts for Model:
Re: Wd oil leak
JMS./MN
10-25-2012 21:47:44
Years ago there was a method posted here to replace the rear engine seal on a WD/WD45- would work the same on WC, WF. Involved a couple plastic half circles and a bit of wire. I printed out the pics- check archives for the procedure. Front crank seal is easy- just pull the front cover, replace the seal and be careful to center the cover on the shaft before tightening. Re zerk on the pulley- IIRC only the older tractors, like WC, had the zerk on the end of the shaft. IIRC it lubed the outer end bearing. Don't remember if the WD45 had the zerk.
