TractorLinks.com
Show Parts for Model:
Re: main brngs
Aaron SEIA
10-25-2012 18:42:41
What tractor? Thats probably about right for a WD. You can also add or remove (I forget which) a shim on the oil pressure regulator. Oil pressure on a W engine is controlled more by cam bearings than mains. I'm sure you could roll in new mains, though.
AaronSEIA
BushogPapa
10-25-2012 20:54:59
 Re: main brngs in reply to Aaron SEIA, 10-25-2012 18:42:41
On these, you don't "just roll in new bearings".. You must adjust the shims on each one..
Oil pressure can be affected a great deal on these by the Back-Pressure (restriction) to flow in the standing tube, in the oil filter.. Are you sure it is in there..?? Few gauges will read accurately at such a low pressure..even AC gauges vary.. Put one on from an AC that shows proper oil pressure, to check your gauge..
Ron..
