Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: WD45 Bushings
[Return to Forum]
Meangreen
10-24-2012 05:20:00
98.188.136.175
Does anyone sell replacement bushings for the foot clutch and hand clutch? I have a lot of play in both levers.
[Reply]   [No Email]
bg/mo
10-24-2012 17:48:45
32.178.167.74
 Re: WD45 Bushings in reply to Meangreen, 10-24-2012 05:20:00
Any small machine shop can help you prob reasonable price too, What I do is weld up the shaft where it is worn, Then the guy I take my stuf to turns it back down to right size and bores the pedals out then puts a bushing in to resize.After that good as new.
[Reply]  [No Email]
Butch(OH)
10-24-2012 09:25:43
70.62.13.146
There isn't any bushings. You have to live with the slop or have the pedal or handle bored bushings made and fitted. Usualy the shaft is worn about as bad as the clutch pedal, same with the pin for the hand clutch which can be a real pain to get out of the transmission case.
[Reply]  [No Email]
Skyhighballoon(MO)
10-24-2012 10:44:17
135.245.8.1
 Re: WD45 Bushings in reply to Butch(OH), 10-24-2012 09:25:43
Copy & Paste from my post on this issue from the "other" forum....
Hand Clutch: McMaster-Carr part number 2868T192; Bronze SAE 863 bushing 7/8" ID & 1" OD, 1.5 inches long. Cut it in half and drive half in each side as the pivot is 2.125 inches long. You can get the hand clutch lever out with some wiggling w/o messing with the frame rail.
Foot clutch: No bushing originally (at least not in my 1956 WD45). I bought a 1 1/8 in drill bit and drilled out the clutch pedal pivot. McMaster-Carr part number 2868T201; Bronze SAE 863 bushing 1" ID and 1 1/8" OD, 1 inch long. The pedal pivot is 1.75 inches long so cut a 1/4 off one and drove them in, one from each side. I took the rear of the left side frame rail loose to get the clutch pedal out. Later I realized I think I could of just pulled the pivot pin out from the right side (that also has the brake pedals on the right side). If that pivot pin is REALLY worn you might consider replacing it as well. (as Butch mentions)
While neither was perfect after replacing the bushings, it cut about 90% of the play out compared to what I had and I was more than happy with that result. Good luck! Mike
[Reply]  [No Email]
Butch(OH)
10-24-2012 18:39:01
107.8.46.254
 Re: WD45 Bushings in reply to Skyhighballoon(MO), 10-24-2012 10:44:17
Hmmm, They must have changed the hand clutch lever at some point? I have only fixed the slop in 2 early WDs and neither of those had ever had bushings in them,, at least there was no trace of them left.
[Reply]  [No Email]
Allis Dave
10-25-2012 08:18:22
108.178.224.142
 Re: WD45 Bushings in reply to Butch(OH), 10-24-2012 18:39:01
My 45 has 2 bushings in the hand clutch. There are also two bushings the handle for the hand clutch throwout if I hit a rock.
[Reply]  [No Email]
Skyhighballoon(MO)
10-24-2012 18:46:38
70.230.174.178
Butch - parts manual says hand clutch lever bushings effective SN 34450 & up. Mike
[Reply]  [No Email]
Allis Dave
10-24-2012 05:48:27
108.178.224.142
You can measure the bushings and order new from McMaster-car. THat's the cheapest.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
