TractorLinks.com
Show Parts for Model:
Re: AC B Stub axle replacement
d13series2
10-22-2012 03:54:13
I cut myself a wrench. That is the same nut as the one on the outside, so I used that as a template. Used a piece 1/4" thick stock, 5' long, then cut half the nut pattern into the end, welded another section with the other half of the cut out to it. Now I have a long handled wrench to tighten the outside nut too. IIRC I jammed my pry into the bull gear and the nut was not too bad to loosen. Dick L has it right, loosen the nut, tap or pess the shaft until you run out of play, then repeat.
