Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: New carb on CA floods
10-18-2012 08:08:19
Check your fuel tank vent and make sure it is not clogged up. Pressure build up in the tank will cause that and as the day gets hotter so does the tank and that in turn can build up pressure and that pressure has to go some place and in this case maybe high enough to push the needle out of the seat and cause it to flood
Sel Larsen
10-18-2012 08:29:29
 Re: New carb on CA floods in reply to old, 10-18-2012 08:08:19
Good thought. I'll try that. Last year the old gasket was so dried up gas would slosh out onto the tank on rough ground and mess up THAT paint and I replaced it. Maybe I did too good of a job!
10-18-2012 08:36:50
 Re: New carb on CA floods in reply to Sel Larsen, 10-18-2012 08:29:29
One simple easy way to check that is when it messes up loosen the cap slowly and listen for pressure escaping from the tank. If you hear that then you know you got a problem
