adjusting wide front on wd45
Hossman
Fella's I am wanting to adjust the wide front in a hole or two on an wd45 i had purchased and it looks to be straight forward but was wondering if there was any tips tricks or advise anyone out there had as I aint ever did this before. Grab a hammer and pound away with a wood block or what? thanks for any help, Hoss
Turn the steering wheel to left or right lock. Whichever side you turn toward, remove one bolt and loosen the other. Drop a pin in the hole in the steering arm on top of the spindle. Then adjust that side by turning the steering wheel. Hopefully, your tractor has power steering.
The tie rods will probably be froze up. I tried everything on mine and only managed to bend one after heating it. Ended up buying new tie rods. If you get them apart or have to replace them, be sure and use never sieze.
