merepat
New User
I have a 1949 WD. I need to replace the brakes. Do I have to pull the axle and is there a "keeper" pin to pull?
No need to pull the axle. Tough pin is at the bottom- check archives for ideas to remove pin. I like to drill 3/4 inch hole in flat bar, weld to pin, apply candlewax after heating, and use bar as handle to wiggle pin loose. Use Never-Seize during reassembly. Get the svc manual- I&T AC 11.
