TractorLinks.com
Show Parts for Model:
Re: WD45 AND PLOW REUNITE
Ted J
10-09-2012 08:32:22
Sounds like the clutch plate is wore down. Have you been using it a lot? So that its not stuck? Might have to take it apart and pull some shims out. All depends. We need more info on it? Have you been using the tractor a lot? Does the hand clutch handle just flop forward? There are those that know a lot more than I do about it who can help, but they need more info.
CM BEHOUNEK
10-09-2012 09:34:35
 Re: WD45 AND PLOW REUNITE in reply to Ted J, 10-09-2012 08:32:22
I dont use the tractor much, yes the hand clutch flops forward, I have tried to adjust it but dont work.
JMS/.MN
10-09-2012 19:28:18
 Re: WD45 AND PLOW REUNITE in reply to CM BEHOUNEK, 10-09-2012 09:34:35
There should be a definite "snap" when it goes over center. If not, remove shims at each of three locations around the clutch under the battery box. If shims are gone, you need to split the tractor and rebuild clutch.
