Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: New Carb on Old B
[Return to Forum]
Greg Ballantyne
10-07-2012 14:11:04
69.19.14.21
I hadn't run my old '49 B much for about a year, and the last time I had it running I had to choke it good to keep it running smooth. Then we had several hard downpours in late August and early September, my lane washed bad and I couldn't get the B running to grade it. I drained the old gas out and replaced with fresh gas without improvement, so I took the Carb off and soaked it in a bucket of gas for a week. I tried to get numbers off it for a rebuild kit from this site, but could not find the right number on it. Anyhow after a weeks soaking I just tried putting it back on, and the engine started on the third crank. My B has an electric starter, but the Bendix nut is wore on the inside and sticks on the shoulder of the shaft, you know how they are.... so I use the hand crank to start it. As soon as it was warmed up I went to grading the lane. On the second pass up the hill, the B quit and gas just poured out the carb drain hole. As I was going up hill I had to get the blade off the back (my B has a homemade three point hitch setup I made about 20 years back), drag it off to the side, and drift the tractor backwards down the lane where it sat while I went in the house and ordered a new replacement from this site. I got the new Carb in a few days, and Friday I put it on. That took a while, I had to modify the Carb three ways and the intake just one way, but after about 3 hours I was ready to try starting it. I hadn't hardly twitched the crank and it was running. That new Carb runs that old B like anything. I should have gotten one a few years ago. This site turned out to have the best deal, I believe it was $69 less than the other two I checked out. And now the old B is running like it was new again, or at least the best its run since I've had it.
[Reply]   [No Email]
bg/mo
10-07-2012 16:44:02
166.203.28.44
 Re: New Carb on Old B in reply to Greg Ballantyne, 10-07-2012 14:11:04
Great job,, Got a deal on a carb and got your tractor running. The two together make for a great day.
[Reply]  [No Email]
old
10-07-2012 16:01:34
209.86.226.34
Well your first mistake was to soak it in gas since gas is what caused the problem in the first place. Those carbs are easy to rebuild and once done right will work better then that new one but hey its your machine. A good soaking in a good carb cleaner and a can of spray cleaner and some air and small piece of wire and your old carb would have been as good as new
[Reply]  [No Email]
Greg Ballantyne
10-08-2012 02:06:32
69.19.14.21
 Re: New Carb on Old B in reply to old, 10-07-2012 16:01:34
And to think that all this time I thought that old tractor RAN on gas.... but now it runs better than it has for 20 years.... the only part I don"t like about the new carb is I had to pay $243 for it....
[Reply]  [No Email]
old
10-08-2012 08:39:04
209.86.226.32
 Re: New Carb on Old B in reply to Greg Ballantyne, 10-08-2012 02:06:32
The problem is the old gas had left varnish behind and that in turn is what caused the problem in the carb and soaking it in gas was not going to remove what the gas left behind in the first place. Now if you had used a good carb cleaner soak can and soaked it say 24 hours and then sprayed it out with spray carb cleaner and air and used a small wire you could have saves at least $200 of that $243 it cost you
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
