TractorLinks.com
Show Parts for Model:
Re: WD -- Can't get thermostat housing bolts out... Thoug...
Brian G. NY
10-03-2012 18:34:15
I'm with toy, try heating the housing with out applying heat directly to the bolt head; this will expand the housing and may allow the bolt to turn.
I did say "may"!!
little sweeper
10-06-2012 07:52:09
 Re: WD -- Can't get thermostat housing bolts out... Thoug... in reply to Brian G. NY, 10-03-2012 18:34:15
I have had a lot of luck on my WC with apply heat and then spray PB Blaster on while it is hot. The hot metal will draw the lube in as it cools. Slowly and deliberately and barley wiggle in each direction, once it begins to move, heat and spray again. I like to heat things up and spray when i get home from work and give it a spray in the morning before I leave for a few days to get things started. Good luck!!
