WD 45 Aftermarket 3Pt
Rod in MN
HI A guy want me to restore his Grandfathera original 1954 wd 45 it never sat out side. Isaid just give it a good wash and fix the oil leaks.But he wants a 3 pt. put on it dose someone make a aftermarket one for it what would be $$amount for one. Who makes one???
Thank You
Rod in MN
Many brands of aftermarket 3 points for that tractor. Me I make my own but then I also am a retired welder so it is easy for me to fab things.
I would suggest trying this place. It"s in Eastern Iowa south of Dubuque. Stopped there about 10 years ago and he had an aftermarket 3-pt system for WD/WD 45 @ $100 or a bit more then.
http://www.ironmemories.com
/business/bill-deppe-ac-tractor-salvage
These by the "OK" tractor company look like what I ended up with and seem to have all of the Bases covered..
I started off with the replacement "Wishbone" that snaps into the snap-coupler and added the Sway Plates and eliminated the sway chains..
This one will still retain the Drawbar and "Traction Booster" action on either the Drawbar or 3-Point..
Good-looking product..
Ron..
