TractorLinks.com
Show Parts for Model:
Re: AC WD45 TIMING
JMS./MN
09-30-2012 16:40:20
Aaron gave you the starting info- here's a bit more- he talks about flywheel firing mark. I stick a bent wire thru the plug hole, let it rest on the top of the piston....turn crank back and forth to find TDC. Either way, after that, you need to take off the dist cap and see where the rotor points- that is where you install #1 plug wire. Then install the others, clockwise, viewed from above.
