7060 hydraulic filter warning light
Bill gray
I recently changed all the hydraulic filters on my 7060 But the warning light on the dash won"t go off. Fluid levels are good, all filters installed correctly. Is there a switch you have to reset manually?
No, there isn't anything to reset. Make sure you took the screen out of the old filter under left side of belly of tractor and installed it in the new filter. The sender is just above the right hand filter under the belly of the tractor, make sure the wire is plugged onto it.
