AC bearing part numbers
Don656
Thanks to everyone who replied to my previous post for cross reference to the AC bearing numbers.
I've got a couple of more:
211632 cup and 211633 cone
210116 cup and 210117 cone
Does anyone know what these numbers cross reference to?
Thanks!
All of the cups and cones will have a number etched on them that are the part numbers from the original manufacturer of the components. With these numbers, any bearing supply store can cross reference them and get you new versions, if they are available.
Go to a place like 'Bearings and Drives', or KAMAN, or Interstate Bearing.
Good luck!
I have 2 211632 cups in original sealed boxes. Also 2 211584 cones in sealed boxes plus 1 rusty 211584 which is Timken 1931 in an open box. This is stuff left over from my dad's AC dealership and has likely been on the shelf for 50 years. If you are interested in any of this, I would open the box and check condition of contents before shipping it.
Thanks for getting that number for me. I am just trying to figure out what the correct bearing is for the steering worm shaft. Since my tractor had the link-belt spherical bearing on one end and a timken straight tapered bearing on the other end, I didn't know which bearing was correct or if AC had ever used the spherical bearings or only the straight bearings.
Thanks for the offer, but I found a source for the link belt spherical bearings which I plan to use on both ends of the shaft.
