TractorLinks.com
Show Parts for Model:
Re: ca and d - 14 fly wheel sizes
chalmersbob(pa)
09-24-2012 19:17:32
If you have a D14, you would need the D14 flywheel which is larger then that of a CA for the starter gears make contact with the flywheel ring gear. If you have a CA starter, the gear count will not match. I don't think that there is any difference in the "reach" of the starters for the gears to line up.
Can you look at the flywheel ring gear configuration and compare it to the starter gear?
I know when I tried to match a D14 flywheel to a D15 flywheel, there was an obvious difference in the gears. LOL Bob
Dick L
09-25-2012 06:28:44
 Re: ca and d - 14 fly wheel sizes in reply to chalmersbob(pa), 09-24-2012 19:17:32
The starter housing is in the torque tube so the starter and flywheel will need to be for which ever torque tube you are using. The starter and ring gear must match. The starter drives and ring gears for the CA and D 14 have different gear counts. There is not a big difference but the D 14 flywheel (will not) enter the CA torque tube bell housing because it is larger in diameter.
