| Allis Chalmers Discussion Forum |
Topic: WD45 overhaul parts
[Return to Forum]
| Author |
[Modern View]
| woodman steve
09-24-2012 09:44:27
12.31.97.44
My AC WD45 burns lots of oil and fouls the plugs quickly. I looking to have it overhauled, new pistons, sleeves, etc. Which kits are recomended? Any I should avoid? Thanks! Steve |
| dallis in missouri
09-24-2012 18:02:36
99.48.149.175
Re: WD45 overhaul parts in reply to woodman steve, 09-24-2012 09:44:27
| if you are in a hurry, i have a wd45 engine just overhaul with allis nos sleves&pistons, new valve guides, valves,head planed, rod & main bearing crank turned to .10 under.ran engine on test stand 10 hrs. never been in tractor.no ex.man or carb, does have gov instaled.located in st.louis area.$800.oo. |
| BushogPapa
09-24-2012 17:15:40
173.88.51.117
| As Old says, get things ready.. See if the Crank is not needing ground (probably not) and see if the engine Block will need "Pinned". That would usually only be if there is a crack in the lower web, between cylinder # 1&2.. The usually rebuilt kit has 1/8" larger bores (4 1/8") and you should have a choice of a couple compression ratios.. I chose the early D-17 rebuild kit, with 7.4:1 Compression and it has worked well for nearly 30 years..! I did eventually change over to 12 Volt, as 6 is marginal..usually would only turn it over ONE cylinder at a time... Rebuilding is straight forward..get all the dirt out of the "O-Ring" area of the sleeve/Block location and use plenty Permatex #2 Non-hardening sealer when installing the sleeves.. Have the surfaces that face the Head Gasket VERY Clean and expect to see some seepage out the spark-plug side for a short while.. The plate between the rear 2 Head Bolts can leak and need attention, if you are not lucky the 1st time.. I like to use Hardened Bolts of the correct length, with Hardened washers to mount the Int/Exh manifold.. I rub "Hi-Temp" Silicone into the asbestos gasket material (white rings) and let it hold the gaskets and metal caps in place on the manifold tubes, while I slide the assembly in place..I feel it makes the gaskets last longer, too.. I have used 318 valve retainers to increase valve spring pressure and they worked well.. Increased seat pressure will help prevent burned valves.. DO re-use the "Cir-Clips" on the valve stems..above the valve seals...(you are going to install Umbrella-type valve seals, arent you)..!! Spend the time to Verify the clearances on the Main and rod bearings, while you are installing them.. When you remove that last pair of shims and it tightens up, put that pair back in and you KNOW it is correct.. These are not hard to over-haul and they WILL out-last YOU..!!! Find an original "Nelson" Muffler, so it Sounds RIGHT, while you are at it..!! Ron.. Ron.. |
| old
09-24-2012 11:47:02
209.86.226.27
| Back up a bit. Go to step 1 before going to step 10. First off get the machine shop work done and then if your lucky they can get the parts you need and that way you know they are the correct parts. Till you do the machine shop work you have no idea if you need what size any thing |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
