part for allis chalmers D15 dozer
Anonymous-0
Hi, Have a H3 D15 gas powered allis chalmers dozer. It has a shuttle clutch.
What I am needing are clutch shims.
Sizes I need are .005 and.010. I need 6 of each of these if possible. If there is anyone out there that has any idea as to where I might find these I would really appreciate it.
Thanks So Much
At the AC dealer where I used to work there was a drawer full of shims. Some were the long and short ones for the power director clutches. I assume the shuttle clutches used the same shims.
No AC dealers you can contact?
Is that something you can cut out yourself " We use to buy .005 and .010 stock and cut with heavy sizors. Used gasket punches to puch out the holes. Little tough on the punches, but does work.
