| Allis Chalmers Discussion Forum |
Topic: c motor swap
[Return to Forum]
| Author |
[Modern View]
| nl00sb
09-22-2012 14:05:57
142.105.190.118
can a d 12 or d14 motor be swaoed into a c or ca if so what mods need to be made |
| nl00sb
09-23-2012 08:33:35
142.105.190.118
Re: c motor swap in reply to nl00sb, 09-22-2012 14:05:57
| dick i thought i saw on here that u did a 4' stroke in b-c-ca motor did u do a welded crank or offset |
| Dick L
09-23-2012 09:43:52
50.51.144.188
Re: c motor swap in reply to nl00sb, 09-23-2012 08:33:35
| Both the same. To stay standard you weld, or the crankshaft grinder welds, on the out bound side of the rod journals and grind the journals to standard which is called off set grinding. If you off set grind without the weld you can not use standard bearings which I wanted to use. |
| Dick L
09-23-2012 07:46:50
50.51.144.188
| The flywheel and starter does, as Steve stated, have to be from the C or CA. Those from a B will also work. The D 12 or D 14 has a front end mounting to the block in the same locations but they use 5/8" cap screws instead of 1/2" studs that the C uses. The front of the block on the CA is also taped with 5/8" threads using stepped down studs to 1/2" which both the C and CA front casting is drilled for. Finding a set of four CA studs will make the fit easy. You can drill out the C front to the 5/8" holes and use grade 5 or 8 cap screws if you care to. In using the 5/8" cap screws will mean you will have to grind out or machine away the casting to get a wrench on the heads. No big changes to make. |
| nl00sb
09-23-2012 06:44:30
142.105.190.118
| have you done this before and how much longer arethe motors if u have ever measured them |
| steve(ill)
09-22-2012 19:01:09
74.36.183.47
| the small B first came with a 116 inch motor. Later the C and B both had the 125 inch motor. Bigger motors with the same bell housing pattern were used on the D10-12-14-15. Motors of 138, 149 and 160 inch will all fit the bolt pattern. Flywheel and starters need to be matched up. Motors are slilghtly longer and hood may not fit as well. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
