merepat
New User
I have always had Farmalls, but I recently bought an Allis Chalmers WD. I"m not getting any spark. I don"t have a wiring diagram.
What do you need a diagram for??? As long as you have power to the coil if it is battery ignition then your spark problem is that the points need cleaned or replaced. If it has a mag then again likely to be the points. Either way be it farmall or A/C or ford or what ever trouble shooting is the same and on most when you have no spark the first thing you check is that the points are good and that you can both hear and see a spark at the points when you open and close them by hand
