TractorLinks.com
Show Parts for Model:
Re: Wheel Issues
Aaron SEIA
09-18-2012 15:48:34
You need the rim off the center, or the whole thing off? Rim off the center requires removing the 8 bolts that hold the spinouts to the center. The entire rim/center can be taken off with a small bottle jack. Hold it in horizontal with the pump down and you can press against the rear housing. The washer trick will work if not too bad. I've seen people take a section of good rim and weld it in.
AaronSEIA
WiOrange
09-18-2012 18:14:34
 Re: Wheel Issues in reply to Aaron SEIA, 09-18-2012 15:48:34
Aaron-
Good point on the outer vs the whole wheel.
The valve-stem hole isn't too bad. Maybe 3/16ths to a 1/4 bigger with a 'hook'. Washers should do it.
Thanks for answering!
