TractorLinks.com
Show Parts for Model:
Re: Allis B steering
Ted in NE-OH
09-18-2012 15:48:05
On the back of the steering gearbox and behind the starter there is an adjusting screw and lock nut. It is adjusted as follows. Turn the steering all the way to the end, either left or right. Loosen the lock nut and tighten the screw until it stops, then back it off 1/8 to 1/4 turn and tighten the lock nut while keeping the screw from turning. Note you will have to remove the starter to get to this screw.
steve(ill)
09-19-2012 18:54:08
 Re: Allis B steering in reply to Ted in NE-OH, 09-18-2012 15:48:05
one manufactured box has the set screw on the end of the shaft... i think the other has a cam bolt on the cover plate? YOu loosen the 4 nuts on the cover plate and turn the cam bolt slightly to move the gear closer as i remember ?
mwilke
09-18-2012 18:04:37
Thanks for the help. I'll Try to see what I can do with your advice.
Ted in NE-OH
09-18-2012 17:03:35
Not sure if both Gemmler and Ross steering gear boxes BOTH have the adjustment or not. Can't remember.
