Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: install a B wishbone wide front on a WC
little sweeper
09-18-2012 15:00:14
thanks for the reply, did you run the steering shaft in the same location, down the right side between the engine and frame?
mo cc-puller
09-18-2012 17:58:40
 Re: install a B wishbone wide front on a WC in reply to little sweeper, 09-18-2012 15:00:14
Yes I did, I took off the square block the rod goes through. Made a guide above the U-joint like a styled WC. Turn the shaft to the center of tractor. Put on another U-joint then weld another guide to the bottom of the motor mount angle iron. Then on to rack & pinion. I had already replaced the steering rod w/ high strength tubing which probably made it easier. Doing that loses about 20 lbs. Those rods are HEAVY. Hope this helps.
Copyright © 1997-2015 Yesterday's Tractor Co.
