TractorLinks.com
Show Parts for Model:
Re: install a B wishbone wide front on a WC
mo cc-puller
09-17-2012 17:56:07
I built a light front for a WC but only used B spindles. Take out all the old steering down to framerails. Weld in 2 pieces of channel about 3 in. apart. Put a swivel pin between them. Build a triangular frame down to desired height & width. Weld on pipe to fit the B spindles. Drill & tap pipes for grease zerks. Use a rack & pinion for a dune buggy-much cheaper than car. I thought it was too hard steering so put a steering quickener for race car in the steering rod turned around backward. BTW 5 bolt aluminum wheels fit a B hub perfect. I built mine mostly out of aluminum & lost about 150 lbs. I've pulled up to 5500 w/ 16.9-38's on with no front end problems. Don't have any pics but hope this helps. Good luck.
little sweeper
09-18-2012 15:00:14
 Re: install a B wishbone wide front on a WC in reply to mo cc-puller, 09-17-2012 17:56:07
thanks for the reply, did you run the steering shaft in the same location, down the right side between the engine and frame?
mo cc-puller
09-18-2012 17:58:40
 Re: install a B wishbone wide front on a WC in reply to little sweeper, 09-18-2012 15:00:14
Yes I did, I took off the square block the rod goes through. Made a guide above the U-joint like a styled WC. Turn the shaft to the center of tractor. Put on another U-joint then weld another guide to the bottom of the motor mount angle iron. Then on to rack & pinion. I had already replaced the steering rod w/ high strength tubing which probably made it easier. Doing that loses about 20 lbs. Those rods are HEAVY. Hope this helps.
