| Allis Chalmers Discussion Forum |
Topic: basic wiring fix for wd
[Return to Forum]
| Author |
[Modern View]
| Hoenes
09-14-2012 18:28:05
99.195.119.198
I'm trying to get an occasional miss out of a wd. The switch was rusty, so I bypassed that. It worked for a while, but now its back. I have a 12 volt battery, and I am still using the 6 volt coil, with the (mopar style) coil resistor. I am going to put a 12 volt coil on, to get rid of any possible loose connections. At what point do you switch to negative ground? (At present, no charging system is up and running) I just take a hot battery with me, which has been fine for Saturday uses. Do I leave it pos. ground, or switch it? What are the bare minimum wires I need (besides hot to coil and starter)? |
| WiOrange
09-18-2012 13:13:53
50.50.70.255
Re: basic wiring fix for wd in reply to Hoenes, 09-14-2012 18:28:05
| | This may be an aside to the wiring issue... If the miss is isolated to one cylinder you can run a hotter plug there. |
| steve(ill)
09-15-2012 17:50:10
74.36.183.47
| 12 volt coil is a great idea. Apparently you have a distributor. Just make sure the hot battery terminal is connected to the same hot terminal on the coil. (- to -) or (+ to +) |
| steve(ill)
09-15-2012 17:56:37
74.36.183.47
Re: basic wiring fix for wd in reply to steve(ill), 09-15-2012 17:50:10
| just leave out the ballast resistor on the coil.
| BushogPapa
09-15-2012 11:15:42
173.88.51.117
| From solid past experience:... Even ONE drop of water in the sediment bowl will cause an occasional Miss... NO idea why, but it will happen..!! Plugs are New..??? Enough fuel turned to the engine..? Narrowing the gap on the plugs may make a difference..but, you may have a bad plug wire shorting or cross-firing..?? Ron.. |
| soundguy
09-14-2012 20:04:32
184.245.71.12
| | if going 12v, if you ever plan to throw an alt on.. just throw it in negative ground. I'd get a napa ic14sb coil for about 16$.. get rid of the resistor.. get a new ignition switch. clean all the grounds .. cables and connections. you can get a delco 10si alt for about 30$ at the auto store.. |
| JMS/.MN
09-14-2012 20:02:17
209.237.125.241
| Do you have a magneto or distributor ignition system? If it is original magneto system, the rest of the electrical system has nothing to do with a miss. |
| old
09-14-2012 18:44:08
209.86.226.32
| One set up that way you can go + or - ground as long as the coil is hooked up the same as the ground. No charging system no big deal. Shoot set up that way and you want as little number of wires just a simple hot wire from the battery to the coil and the normal battery cable to the starter is all you need. I have run tractors for months with a none working charging system you just have to charge the battery once in a while |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
